TwinTurbo.NET: Nissan 300ZX forum - knock sensor, knock sensor harness (n/m)
SactoTodd
on June 09, 2006 at 10:27 AM
What else should I replace while doing a clutch and flywheel
posted by Payce
on June 09, 2006 at 10:14 AM
Payce
10:14:05 06/09/06
Downpipes, check coolant hoses on back of motor,
10:16:31 06/09/06
Driveshaft (n/m)
dream Z (MD)
10:19:59 06/09/06
knock sensor, knock sensor harness (n/m) -
SactoTodd
10:27:59 06/09/06
glad someone mentioned it... HUGE 2nd. (n/m)
Waco300zx
10:39:53 06/09/06
Same as a det sensor right? (n/m)
Payce
10:52:20 06/09/06
det sensor = knock sensor (n/m)
EricTTZ
11:17:00 06/09/06
if you are running an ebc, what good does a knock sensor
Moxie
11:27:53 06/09/06
It sends a voltage to your ECU. (n/m)
Kenny
11:31:48 06/09/06
Re: It sends a voltage to your ECU.
Moxie
13:25:42 06/09/06
Tells your ECU to put you in safety boost after detonation
brahmabull (NoVA)
12:30:56 06/09/06
did you read his post?
myzislow
13:00:56 06/09/06
It does a variety of things.
John B.
14:45:45 06/09/06
You'll need the Craftsman midget hand attachments.
Spee
12:44:06 06/09/06
HUGE 2nd...no way I could get my canned ham mitts in there. (n/m)
Unluky (MO)
13:55:35 06/09/06
transmission fluid (n/m)
RedSER13
10:31:53 06/09/06
rubber shift fork boot, short throw shifter, shifter bushing (n/m)
spyhunterTT(nj)
10:32:21 06/09/06
I was going to do those things at a later time, can the
Payce
10:51:49 06/09/06
it's tricky, but yes (n/m)
spyhunterTT(nj)
10:53:36 06/09/06
easy as pie when you take the slave off (n/m)
mousersix (San Antonio)
11:53:04 06/09/06
yo guys, just a question since we're on the topic of
CRAZZEPETE.
10:34:01 06/09/06
about this much: >< (n/m)
SactoTodd
10:36:00 06/09/06
if you have lateral movement, replace shifter bushings (n/m)
Crim
10:42:36 06/09/06
I have brand new bushings installed and I have about
doug8867
11:06:34 06/09/06
I've recently noticed the same problem...
hottysmerf
12:11:30 06/09/06
Rings, turbos, injectors. (n/m)
Kenny
10:35:29 06/09/06
2nd that but dont forget Rod Bearings (n/m)
kryptonite729@VP
11:06:44 06/09/06
Good looking out. (n/m)
Kenny
11:31:04 06/09/06
What about Subframe Bushings? (n/m)
Barry'z (NJ)
12:00:07 06/09/06
Those were implied.
Kenny
12:42:58 06/09/06
wrong end of the car, n00b. (n/m)
Spee
12:45:48 06/09/06
Pfft... as if you expected more from a 2+2 owner.
Dave N
12:50:25 06/09/06
Uh .... Spee, Dave,
Barry'z (NJ)
13:12:44 06/09/06
...and valve guides. (n/m)
T0M
13:09:56 06/09/06
...and replace/rebuild/clean lifters. (n/m)
John B.
14:48:26 06/09/06
...and naturally a new oil pump. (n/m)
CaliguyPurdue
15:24:29 06/09/06
Everyone says to replace them..
John B.
15:46:40 06/09/06
I was just chiming in to add to the list :) I replaced mine
CaliguyPurdue
16:10:42 06/09/06
Downpipes and transfluid. (n/m)
zboost(tx)
10:45:12 06/09/06
Don't forget oxygen sensors. (n/m)
BradZ (FL)
11:54:56 06/09/06
Nah, you can get to those easily later. (n/m)
zboost(tx)
13:58:00 06/09/06
Basically, a bunch of stuff.
hottysmerf
12:12:27 06/09/06
Did mine about a year ago
SuparexTT
13:19:37 06/09/06
rear shaft seal. My mind is fuzzy but I believe it's
PiotrC70
13:35:57 06/09/06
LMAO! My $450 clutch change wound up costing me $1600 with
Unluky (MO)
14:01:06 06/09/06
Replace your stock turbo, fully rebild engine and bottom end
rogeristheman
18:23:27 06/09/06
Just a little much don't you think
dream Z (MD)
20:44:33 06/09/06
